I want to installl body side moldings on my Sonic sedan to prevent door dings. GM offers a molding kit for about $ 120, but you need to have them painted to match your car color and typical body shop charge for this ranges from $ 125 to $ 250. It is more cost effective to buy custom painted moldings from an aftermarket source for about $ 140. I saw these on ebay and also there are some other sources.
Where is the paint color code located on this car? They list two white colors (ice white and olympic white) and I do not know which mine is without the code. Were both of these white colors offered in 2013?
I believe the paint code is located in the trunk near the spare tire. I assume that your car is Summit white. Pretty sure that Olympic white is the predecessor to Summit white (same paint code).
I looked up a water pump for 2013 Sonic 1.8 liter engine on http://rockauto.com and they have 3 different ones listed. The A/C Delco pump is part # 251752. It states there that it has a stamped steel impeller. I hope that this is the OEM pump.
