Dubbs_RS
So I installed a set of eibachs about 2 weeks ago. I did the fronts, dropped the car down and turned the key (was turning it around to put the back end into the shade) and noticed that both the stability control and abs lights were on. I just attributed it to a fluke at the time, so I continued and changed out the rear springs as well. When I was done the lights were still on. Took it for a drive, poked around in the wheel wells for a couple mins and the lights went off, so again I assumed it was a fluke.
Now just a couple of days ago the 2 lights started going on and off intermittently (seemed to happen when I was hitting nasty bumps, but that could have been my imagination). As of yesterday the lights have stayed on consistently. It seems like a faulty or loose connection on a sensor to me because it was happening intermittently. Anyone have any ideas on what could be wrong? Could it possible be an alignment issue because I haven't had an alignment since installing the eibachs.
I know there are a couple other threads about the stability control light staying on, but none were terribly conclusive and many didn't also experience the abs issue like I am. I am hoping my specific situation can help narrow the problem down. Thanks!
