BSD
So I got a sick deal on a snow performance stage II MAF kit with other goodies and have some questions for those that have already done this or know more about water/meth than me.
Background: I'm running Trifecta Full Legacy and plan to keep my tune non-meth dependent (IE I run out of juice or fail to inject while driving and my engine doesn't asplode) for a few months while I work out the kinks.
First, the golden question: where should the injectors go? The instructions and most sites recommend as close to the throttle body/intake mani as possible however this would be past the IAT2 sensor. Would it not be prudent to inject before the sensor so the ECM knows that the post intake temp is lower and thus advances timing? Or does the ECM go by the knock sensor and injecting close to the TB/IM would be smarter to avoid heat soak?
If it's the latter does anybody know where I can find a TB spacer other than DDM's? I'd rather not go with them after the service I've received in the past.
Additionally I don't have a meth bung on my MPFab hard piping. I tried to work something out with MPFab but it didn't pan out and I don't really have access to a welder. The instructions say to drill/tap a hole to install, is that safe? Is the piping thick enough? I found a site that sells a 1.75 inch chunk of pipe with a bung on it and could add it down by the intercooler exit. Thoughts on that?
I have one other question that I can't seem to get answered. Is it better to have two smaller injectors or one larger one? Does it even matter? (I'm thinking probably not)
One of the goodies I got was SafeInjection which is a module that can either open the wastegate, open the BPV, or signal the ECM to cut boost should meth injection run out or fail. Can I plug it into the ECM and could Trifecta tune for it?
Lastly, I'd really like a way to turn meth on/off safely like a toggle switch in the cabin that way I can not use it when I'm just driving to work or getting groceries. Is this possible and if so how would I do it?
I realize most if not all of these questions would be better directed to Trifecta. That said, their turnaround time leaves much to be desired so it is my hope that I can get some of them answered here and send the remaining to Trifecta to expedite their response.
Thank you all.
Thank you all.
