Gimpster
Hey everyone, this will be a work in progress/diary DIY. I will keep editing this first post until conclusion. I typically do my big forum posts like this, so sorry. I HOPE to at least have the proof-of-concept running/idling the car 11/18/2017. That all just really depends on the time I have and if all of my parts arrive on-time.
Okay, so first off: I really like the BNR coil upgrade. That has to be one of the better packaged aftermarket coil upgrades I've seen... on any platform. Hats off to them, really.
That said, a.) I am a poor person, b.) I do my own tuning (HPT) and c.) I like to DIY in general anyway.
Disclaimer: If none of this makes sense to you, save your pennies and buy the BNR kit
Also, you will need to own or have access to a tuning solution which will allow you to modify your spark dwell settings.
My goal is to have no more than $150 into this setup.
Parts Needed
Coils:
Besides having owned a lot of various LS powered things, I also own a Mazda Miata. It runs a standalone (MegaSquirt), and on that car I chose to use the GM D585 (AC Delco PN: 19005218) coils. These are all over the junkyards CHEAP, and a pretty hot coil. I typically snag them off early/mid 2000's truck and SUV's. I'm not saying these are THE BEST GM COILS, but it's light years ahead of most stuff and what comes on the Sonic. You are typically talking 40kV+ on the better models of LS coils.
One thing to know about the D585 is that its a semi-intelligent coil. It is known to fire when saturated > ~4.5-5 milliseconds dwell no matter what you tell it. This is more of an issue for the people making extreme (think 1000+) horsepower, and why it has fallen out of favor a bit.
You will need four of these. If you buy them at the yard, snip off the connector leads too.
I highly recommend genuine/OEM coils. The Chinese junk (even AC Delco branded) have often proved to be unreliable or not perform. That goes for any LS coil really in my experience. This is what the D585 looks like:
Male ignition plug connector, pins, wire and wire seals:
I want my conversion harness to look OEM and professional, so I put in the work to track down the part number of the coil side plug, pins needed and wire seals. The harness plug is what mates with the stock engine harness coil pack plug, if that wasn't clear.
Harness Plug - Qty. 1 PN: 15359189
Pins - Qty. 7 (I recommend buying more!) PN: 54001845
Wire Seals - Qty. 7 PN: 15366021 OR 15366060, depending on what gauge of wire you use. More on that below.
15359189
54001845
15366021
15366060
I am using an assortment of 20AWG TXL wire to complete the project. I looked at the car side of the harness, and it seemed to be about what they are using. If I need to upgrade sizes later (would only be on the +12V and negative if I did) I can. I just have piles of this stuff around from building harnesses for other stuff. Since I am using 20AWG, the white seals (15366021) work fine. If I was going larger, I would need to use the blue (15366060) seals.
You can get a cheap assortment of TXL wire from people like this: https://www.amazon.com/gp/product/B01FJ21RDM
You will also need the four pigtails mentioned under the coils section. If you can't get them from the junkyard, look on eBay... you will see a zillion different LS coil harnesses for like $17-20 dollars you could buy and cannibalize for this project. I'm sure the coil harness plugs can be sourced with wiring as well.
Coil Bracket:
I will be using ICT Billet PN: 551562 D585 coil relocation bracket. I am unsure yet if I will mount the coils to the valve cover, the firewall, or some other place. It actually comes with two brackets, so you can make another set for a friend or .. whatever.
https://www.amazon.com/dp/B01M4LYET8
It should go without saying you can make your own bracket, or re-purpose a bracket off an LS motor (they bolt to the valve cover) if you are very budget minded. I almost did the latter, since I have a ton of them in a box... but wanted something a little nicer looking
Here is what my ICT Billet brackets look like with the coils assembled on the bench:
Spark Plug Wires:
I will just be using LS powered truck straight boot wires. I have a ton of old ones laying around my garage, and will provide some part numbers at a later date for everyone.
Example:
Wiring Diagrams
Ignition connector pinout (NOTE: this is as viewed from the engine harness!):
Ignition coil pinout:
Full wiring diagram to coils:
Parts Needed
Coils:
15359189
54001845
15366021
15366060
Coil Bracket:
Spark Plug Wires:
Example:
Wiring Diagrams
