EyeluvSmegma
Cannot wait to see an update on this.... Even if it doesn't add much power, I see tons of possibilities moving forward on my build.
I see the intake is up!
Lol Laingsburg? I grew up in Byron. Currently in GR.LOL.....we finished testing last night. We have results for the intake manifold and our air intake box. I hope to have dyno sheets up tonight.
The manifold could add .001 HP, and I'd still buy it. Because..... not plastic. And ports. I love ports.
Just make sure it doesn't "loose" power, some manifold put power up so high, and you loose so much low end. Not saying this will, but need to know where it adds power.
That is why a true "manifold change over only" before and after is needed, you can flaw the data real quick by adding an intake tube at the same time; as the intake tube may be making up lost power and some. Meaning just an aftermarket intake tube, with a stock manifold can make even more power.
Interested to see the manifold gains and awesome to see support to this community!
Chances are the ecu is dialing power back to its preset parameters. Definitely get it tuned stock, then add manifold and tune/dyno again to see actual gains.Completely agree with you, and we were a bit shocked by the results. We typically see very good gains with intake manifolds, but this was not the case. I can tell you we did not lose any power, but we did expect higher results then what we have. Keep in mind the manifold is the only product we used during testing no other performance modifications. We also have not tuned the vehicle yet, so this is how the OEM ECU reacted to the manifold.
Looks good, however it appears adding the manifold lost about 1 HP?
You tested the stock manifold and the air box on 2-5-18 (looking at the other thread) and made 135 HP. Now on 2-7-18 you have it on the dyno with the air box, and the manifold and are at 134 HP?
The air box add makes sense compared to other intakes on the market, and has a nice gain.
Also it would be nice to see a same day, back to back dyno on each one by themselves, like your air box. Dynos do adjust some, but only gaining 4HP is questionable on the day to day.
Never the less this looks great! Also each application is different (each member has different mods), so some may gain more, some may gain less... So don't take any of this wrong please![]()
