These eyes.....
as you can see the work needed to make these fit...
Stock barrels unfortunately just aren't going to fit. Custom black ABS barrels coming soon. I had to split off the barrels from the corner reflectors. Mounted without issue.
Miller Lite barrels? Finally finished the templates for the new barrels. One last test over the weekend and sealing these bad boys up!
I'd have almost had you keep the Miller Lite logo on them.![]()
very nice. Is this a one time deal or are you going to start selling these?
Would that function properly? Because that would be dope. I would be in for a set if that could work with no major problems down the road lol
Thas hot.
Andrew - you need some type of automatic siren on your car, like those blind spot sonars set up to blast someone with a horn if they get too close to your car. Those lights look like money.
@Beast - Such an awesome build, and your work is so meticulous! I'm assuming all the bracketry is necessary because of the JW lights?
An MH1 would be far easier to install, right?
I'll look to start my retro in the Spring once I get all the parts together. Still debating quad projector vs dummy proj's in the high beam cans.
it's not the size, it's how you drive it....
I've thought about buying a dummy projector for my high beam also to run quad demon eyes. Still might be on the list.
Lite em up! I wanna see!!Brett says there's one final test and then the sealant goes on.
Tapatalking on my iPhone 6.
