sx sonic
I've noticed it but the jump is rather small. Most e-throttle programming will compensage for dropping revs by giving throttle.
Example is my old 2006 LS2 GTO. Set handbrake, and start slowly releasing clutch with no throttle. The ECU will really play hardball to keep the revs up to where the car would squat and strain against the handbrake. Quickly floor the clutch and watch the revs spike to 1500 or so. I've not heard folks on the forum thinking that this behavior would reduce clutch life. Perhaps this is rather different from the Sonic.
The Sonics (atleast 1.4t) take off assist is much different, it is minor and short lived, and thus ineffectual.
From my observations it is not intuitive.
It appears to operate on only 2 parameters.
#1 is clutch release, near the engagement spot it will essentially give a blip of the throttle, above a certain speed it becomes disabled.
#2 is time, it is only active for a short amount of time. Once that time limit is met the ECM essentially lets up on the throttle.
It also doesn't seem to work very well with driver commanded pedal request, as evidence by the multitude of different launch methods drivers use to take off smoothly, which is often different than their normal manual trans launch methods.
