desert sonic
Hello,
Interested in getting some guidance on DTC code C0561-77, for a 2015 sonic LTZ 1.4L turbo. This code is the latest issue with this car. Some background leading up to this issue:
1.Car problems started as high temp warning light; flushed coolant system using flush machine.
2. Noticed crack in overflow reservoir during inspection after flush; replaced reservoir.
3. Continued getting high temp warning; had dealership assist with diagnosis, conclusion: tstat.
4. Replaced tstat, housing, gasket.
5. Started getting CEL light randomly (sometimes would show, sometimes wouldn't; CEL would be on while running, but after engine stopped running, CEL wouldn't show on restart; sometimes wouldn't show at all during run, stop, or restart).
6. Used scanner to pull code C0156-77, checked code list for explanation:
- System Disabled Information Stored Engine Speed Out of Range
7. Began researching DTC code, getting various results from: replacing ECM, BCM, EBCM, grounding issue, glue on electrical connectors
confused
, etc. which translated to me as "electrical issue with no clear cut answer"
So, now I'm hoping I can get some info from this forum. Not really interested in throwing money/parts at the car until this issue magically goes away.
