Blue hedgehog
Well I didn't get any of the bolts from GM after all but from a local hardware store. I can tell you the two small screws are actually 6-32 bolts (not metric), I purchased 1" long stainless allan bolts and fender washers, but the bolts could be shorter.
The GM torx head screws are 6-32. Most people including myself don't bother installing those. I only use 4 on mine (no rattles).The two original bolts up front and two in the rear in the slotted holes. It makes for a much faster removal when doing an oil change without a jack or ramps. Loosen the rear bolts, remove the front bolts, remove the belly pan.
