$ub$onic
The Sticker Guy
So I changed the fluid in my f17. I change it to royal purple max gear 75-80 something weight. Here is what I did
Tools needed: 7/8 socket
11,13 socket
2 quarts of gl4 spec oil
Drain pan
Jack,ramps,lift,whatever
Oil resistant silicon on hand
Rubber hammer (maybe)
You will be filling it though the reverse light switch. You will need to disconnect the wire and (I used ) use a 7/8 socket. It is just snugged on so a light twist should work
bottom view
Then you will need a 13mm to unscrew the fluid level cap seen here
. It's hard to see but it's very easy to find under the car
Then use a 11mm to unscrew the 10 diff cover bolts
Now listen VERY CLOSLY 1) do this by hand 2)you will get 5-8 turns out on the screw and they will get tight DO NOT FORCE THEM!!!!! Screw them back in alittle then back out. If you force them you will more then likely strip the threads. Take out all but 2. Slowly loosen the last two and the cover should just come off. If you get the two screws a majority of the way out and the cover is still attached hit lightly with a rubber hammer
Beings that its a new car you should not need another gasket but have a oil resistant silicon on hand just in case
Next re apply the cover and torque to 12 foot pounds DO NOT OVER TORQUE!!!! Torque in a star pattern
Then fill with oil through the switch hole till it runs out of the fluid level cap hole
When finished re install all plugs make sure you just snug the reverse switch
Make sure nothing is leaking
Disclaimer: this is how I did it, I am not responsible for your mess up
So far it seems to shift a lot better and I will report more info as I drive more
11,13 socket
Drain pan
