I've been on the forum since Jan 2013 but I think my time with the Sonic is coming to an end. I haven't fully talked myself into it selling it yet but if someone came to my door with $6,000 we might make a deal. This Sonic looks original from the outside so it doesn't really stand out from the crowd but it does have some under the hood mods as noted below and does have an interesting documented history on this forum.
This is the Sonic that had the first Buick Encore 11.8" front brake conversion on this forum, maybe you've seen that thread.
http://www.sonicownersforum.com/forum/threads/buick-encore-brakes-to-sonic.17075/
It had one of the first (if not the first) RS read disc conversions on this forum, perhaps you've seen that thread.
http://www.sonicownersforum.com/forum/threads/drum-to-rs-rear-disc-conversion.17350/
This is was one of the first Sonic's on this forum to be tuned using HP Tuners and has a sticky thread. A bunch of us were figuring that out together back then, maybe you've seen that thread... good times.
http://www.sonicownersforum.com/forum/threads/taking-the-mystery-out-of-tuning-the-1-4.15371/
And of course my build thread.
http://www.sonicownersforum.com/forum/threads/stews-sonic.14039/
Right now it's got about 145k miles on it, needs to be washed and needs the rotors turned because they pulse. And the rear pads need to be replaced due to some uneven wear when first fiddling around with rear brakes after the conversion. It has been driven spirited but never thrashed, still has the original clutch which holds as tight as new so you know it's been driven responsibly. Interior and exterior are in very good condition and never smoked in. Everything works and the motor/transmission have never been apart.
Still gets mid-30 miles per gallon and has a few upgrades as seen in my signature:
- 23 PSI tune with HP Tuners, about 180HP/210TQ at the wheels
- 42 lb/hr genuine Bosch green giant injectors
- Ported intake manifold
- Hard piped SAB, snorkel delete
- Bypassed BPV solenoid
- 11.8" OEM front brakes
- RS rear disc brakes, RS springs
- MPFab DRS (not currently installed)
- Chevy Cruze auto dimming rear view mirror
- Buick Verano dome light w/ accent lighting & backlit map light buttons
- Painted bowties, black lug nuts
- 225/45-ZR17 tires
I'm the original owner of this factory ordered Sonic, have all the documentation, window sticker, receipts and service records since new. I will be sad to see it go but I think it's time to move on.
PM with any questions.
- 225/45-ZR17 tires
