Since I first bought this car brand new, I've had difficulty shifting into the reverse gear. It only occurs when you first engage the clutch and shift into reverse. But, if you leave the clutch engaged, you can go in and out of reverse with no problem. (But when in real life are you really ever doing that?).
There will be a large grinding and clunking sound. The car will buck and at the end of the throw, the clutch will have a small vibration.
I've brought the car into the dealer two times. The first time they said it was normal. The second, and most recent time, they had the nerve to tell me that I was shifting incorrectly. Unless I take 5-7 seconds to shift into reverse, it will do this every single time. This is not normal and has nothing to do with how I'm shifting.
Has anyone had similar issues or have any idea as to what the problem may be?
