Finally, I got a car with an engine where I can easily get to the spark plugs without an act of congress and the blood of a virgin.
Thanks for all the valuble info.
Sorry for the delay ...wife...kids...you know how it is...
Anyway Autozone is about 10 minutes away and all I bought was a 5/8" spark plug socket (which I already had at home and did'nt realize it.)
Picture 1 shows the tools I'm using for the job. I already had the feeler gauge just hadn't opened it until now.
Picture 2 shows that I had to use a longer extender (fortunately I had that to).
Picture 3 shows the wrench in place to remove a spark plug. By the way I could not believe how easy they came out with almost no effort as if they were just hand tightened. Not sure if this is normal because I beleive I read someone else had to really put some muscle behind it to remove the plugs.
key1
FYI - Did you use anti-seize on the threads when you installed the plugs. I also use Dielectric grease on the boots to make sure they don't get stuck on the plug or in the well.
What was the need to check the plugs? At 900 miles they would show little to no wear at all.
Thanks for adding more details....how much dielectric grease and how did you apply it? Also same question for anti-sieze...
Key1
Spark plug socket is one size, it just had some foam or something in there to hold/not damage the plug. Let me find mine real quick.
-Eric Smit
I don't think there is more than one. If there is, I've never seen it.
-Eric Smit
-Eric Smit
Not sure on the torque specs, I've got an extended 3/8 drive ratchet and I pull with my pointer and middle finger just barely on the end, and pull until my fingers are strainin pretty hard. Normal length socket i'd do the same and then give it a little extra turn.
You could always try tightening a plug just a smidge and note how much effort it took and then duplicate that when you put them back in, if you try tackling this job before getting torque specs
