Not sure if this is of help with the AC, but I also notice a hissing sound, rather like what you usually get with an AC system after cutting the engine when it resets the fluid in the system. It seems to cycle on the Sonic periodically. Not sure why, and it's annoying, but it seems to be remarkably effective at low power in terms of cooling air. The other thing it sometimes does is the sound of the clutch on the compressor is quite clear, which you do not hear at all on a same model year Cruze. I'd like to know if this is something to watch out for, an indication of something that's loose, a bad component, or simply part of the system. This in a 2014 Sonic and I understand there were changes across the GM lineup for 2014 for a new type of refrigerant that's less of an environmental hazard than even r134.
