ThatTmoGuy
Will the IC diverter still work with the new kit?
FYI - I looked into this and it ends up being approx 1.75" ID when you cut back the rubber hose enough and the angle is a little weird going from the stock rubber to the intercooler we are testing. So it can be done if you insert a 1.75" tube into the stock rubber hoses, then get a reducing coupler to go from the 1.75" to the intercooler. The angle is not off by much, but a slight bend in the hard connector between the 2 would work also and probably make it work. The hard tubes we are using in the intercooler kit are all 2" FYI.
I just want hard charge pipes. not necessarily for best performance, but because it would look much better for my BOV.
Understandable, a nice polished aluminum pipe does look better than black silicon.
So now you are opting to do all hard tubes? iirc, on an earlier post you said you were doing all silicone with just the hard charge tube. Hmmm I may want to just wait for all hard tubes. I guess the intercooler is going on my list!
DDM,
Can you tell us the size of the inner cooler your testing? Length, height, depth.
Any idea of what kind of pressure is lost with the bigger core? It looks like it is a bar and plate design? is that correct?
And lastly, I know a lot of people want hard piping all around, but would it be better to do more silicon since it does not retain heat like aluminum would.
Let the testing begin -
This is the latest prototype intercooler, shrouding and tubing that we are going to start testing next week. I will get some logs of the runs and see how it does. Basically this is as large of an intercooler you can fit between the bumper and the bottom of the car and it is as wide as the grill opening, should do the job nicely
No pricing yet, have to make sure all of this will work, then will have some pricing, but should be in the $400-500 range for the intercooler, charge tubes, silicone connectors, T-bolt clamps and shrouding.
DDM can you guys come up with a lighter flywheel?
there is already a lighter flywheel made by Clutchmasters, just like you were told in the other thread.
what happens of i just want a flywheel 8(
Looks great! Myself and others are excited about the specs.
If you dont mind me asking who makes your cores? or do you buy them as a whole already with end tanks? Can you do black couplers instead of blue? If I got a kit I would powdercoat the pipes black as to not draw attention when taking it to the dealer for an oil change.
PS- you should make a matching air diverter for this as well![]()
