I am getting a P0238 occasionally and not sure how to resolve it without altering manifold pressure. It's a little tricky nailing down the conditions triggering it since it doesn't happen very often and I can't drive around with my laptop logging all the time but the conditions where it's occurring seems consistent with the second quote below.
It seems like it's happening when psi is around 23 at around 3000 RPM. That is the max my boost peaks at and it will only get that high 3000 RPM and up. I am hoping there is a solution that does not involve reducing boost, I am pretty happy with my tune except for this little fly in the ointment. My tune is not the same as the one in the tune thread that is stickied, FYI.
Also, you can indeed disable the CEL for this code but that does not prevent you from going into limp mode, it still happens just no CEL.
Searching the forum only pulls up the following two posts with no solutions:
And
Thanks guys and gals!
Well, I have an update. I'm having trouble with a pesky DTC (P0238) where I'm apparently getting a sensor voltage high problem.
Looks like I've got a pretty good reason for the over-voltage:
And
Had code P0238. According to what someone on facebook posted:
ECU saw a boost spike higher than it liked as sent you into limp mode...
P0238 Description
Turbocharger Boost Circuit High Input Conditions
Cause
Engine speed less than 3506 rpm, then the PCM detected that the Turbocharger Boost Pressure input was more than or equal to 4 80v (202 kPa), condition met for 2 seconds
Anybody comment on this for us laymen?
