ChrisJ
I've done this before, not my brightest moment.
What I've found is if you unscrew the plug while putting pressure at the end, so now your pressure is keeping the oil from comming out, once you are sure its totally unthreaded you can pull the plug away all at once and keep your hand out of the super hot oil.
Or, sometimes you mess up drop the plug and the oil gets all over your arm, you sit up fast from the surprise of the hot oil on your hand and bang your head on the hot exhaust pipe and then just lay there feeling sorry for your self with a burn mark on your forehead.
