Yeah I will get a hold of them tomorrow. Hopefully someone else can give some advice like you said since I am by no means an experienced auto mechanic. I did try lifting the wheel hub to raise the upper mounting point on the wheel strut but it needed to be lifted quite a bit and the sway bar ending up hitting the control arm so I don't think I could have installed these even if I wanted to.
I am emailing someone from there now. I'll let you know what I find out.
I just ordered and now I see this? facepalm.
"Have you tried installing this item yet? we have a set on our sonic right now, with no issues. They are a bit longer than stock, but the whole sway bar should simply rotate up to compensate."
This is the response I got. Does this make sense to anyone. Seems like if i rotated the sway bar to make it fit the sway bar would be in a much different position.
can you send a link of the ones you are getting?
$27.67 on amazon with free shipping for the same thing - Moog K80252
Found in another post, these fit the cobalt SS.
There are a few members that are running these, I believe $ub$onic is one of them
i bit longer, they look to be about 3-4 inches longer.
I will be returning mine, already ordered cobalt SS ones from advance auto for 31.00 each after coupon code and pick up in store.:banana:
