I've gotten a couple tanks that nearly got 50 mpg.
How are you tacking your gas milage Marty?? From your post you are going off dic and also hand calc but what are you basing your # off of. For instance I fuel up. -reset DIC and Trip. -refill when I get close to running out of gas. -fill tank. -calc mpg. Trip/gal=mpg that tank, I do this every tank and log it as well as my DIC mpg.
The reason I ask is it sounds like you are doing a lifetime mpg calc. Almost every subsequent tank I've had has varied by atleast .5 mpg even if I made no modifications and had a near identical drive cyles. I've had as high as 49 and as low as 34mpg with an average of ~38-40 mpg (20%rural- 30%city- 50%highway usually). If you are doing a lifetime avg it will take along time to notice anychange and it will be hard to notice if any change was due to drive cycles, mods, gas, etc.
Don't take this the wrong way, I'm not calling you out or saying your doing it right or wrong . Simply trying to understand your style of doing this because I would expect some mild variances between fill ups mods withstanding.
By thw way I saw no definitive numbers to support that either running 93 or a bellypan were better than the alternatives. My max was about 0.5mpg better on 93 vs 87 with very similar drives, but at 500+ miles on either tank simply idleing a little longer a few times could account for the difference. Same with the belly pan but my comparision for it have the bellypans before and after has been thrown off by mods, so I don't have enough data to paint a picture on it..
-tyler
