whitesmoke
No I am going to send a message to wot tonight, they already asked me if I wanted them to check on it
WOT seems to be prioritizing direct contact over BNR or other vendor tickets, maybe try that. I can assure you we are not holding anything up and will provide screenshots if necessary.
Man i think they should give you ur money back.Well it did not go good. Best i could get out of it was 15.88@ 86.7. It was hotter than the other times, 82 degrees but humidity and baro were the same. Most it should have slowed is .2. If this trifecta was making any more power than the scr it should have gone at least as fast as the scr 15.35. 60' was way off too. And the shifting is afu, wont shift in d unless you spool it above 4000 and it is impossible to drive at a steady speed with your foot. I think im going to give up on the trifecta. So far scr is the best out there as far as no bs plug in and go fast with absolutely gorgeous trans program and real nice smooth power curve. And that explosion off the line is like a stick car. My hat is off to superchips for a great plug and play unit that works like a factory program. If you have a stock sonic and you want to go fast with no fuss no muss lol, run to bnr or jegs or somebody and buy one of these while they are still around, you wont be dissapointed. You also have to realize that i have an rs auto with every option available meaning it is the heaviest of all sonics, if you look at the guys on here going 14s there cars weight between 200 and 400 lbs less than my car. If i took 400 lbs out of my car it would go 14.80 as it sits with the scr. So in reality they are not making any more power than i am and they have megabucks of mods.
im real upset, this trifecta thing is not working like I thought it would. as a matter of fact it sucks. ...
I think the only way you are going to get the car set the way you want is hp. If you look at the post stew did with the hp tune pics of the screen on computer it looks like that is what we want, it doesnt look that complicated and you set the throttle percentage where you want it accordingly to pedal position
Thanks stewWhile that post I made with the screenshots from HP Tuners works alright, I recently have been in touch with Jerry at BNR to work out a couple quirks in my tune and would wholly recommend him for an HP Tuners tune. I mentioned in that thread that "this info may not be the only way (or even the best way) to achieve your desired goals" and there are indeed better ways to tune it than what I did.
