anyone think maybe the stock BPV is leaking boost? I've watched the boost go up to 19-20 psi and then fall back to 9-10 psi while still at full throttle, approaching 4500-5000 rpms. i cant figure out what is causing it.
it looks like the absolute throttle (ultragauge) stays at 83.5% when im at full throttle, and i have never seen it at 100%, so i figure that's normal. but if it were closing the throttle on me, wouldn't the absolute throttle position would also drop?
they're the stock plugs set to the correct gap.
is there anyway for me to see the data myself from the datalog that I recorded? I see timing advance on the ultragauge, but I don't see anyway to look at knock retard.
I just sent you the datalog that I recorded earlier today Walker.
I only run 91-93 in my car, whatever the top grade fuel is, but unfortunately, there is no place to get ethanol free fuel close to me.
I'll have to look at it on the shop computer. My laptop ate the hard drive, and i lost the software that was letting me view it.
Stock plugs suck tuned. Should be using coppers gapped to .25
