GreenGhost28
I had tried "no resistor needed" bulb s before and some work and some don't. Kind of hit and miss. Im in the same boat as not want to mount resistors, especially in the back. Still have to swap the fronts to LED. Got the harness wired up, just need to mount the resistors and solder the wires to the resistors. Going to wait for warmer weather for that though.Yep, those will work perfectly. They have the resistors built into the bulb so none are needed to splice.
The difference between bulb types there really comes down to wattage used, with LEDs that really doesn't matter since they use so little due to being more efficient than the standard bulbs.
So all in all, safe, go for it if you guys wants to :banana:
Sent from my XT1080 using Tapatalk
