michaelracer
So I found out that you have to stick the headlight in the oven at 250 degree F for 15 minutes to loosen the glue on the clear plastic to take it off the surround so you can epoxy the halo onto the light, then you have to stick it back in the oven to heat the glue again to get a proper seal when putting it back together. Then you wire it to the same wires as the day time running lights. sounds like you could have a few issues with this installation.
