Well, if it's thousands of dollars, I wouldn't expect anybody to have an interest. I sure wouldn't. As these motor get older, heads are going to come off, valves are going to be replaced, and while they're in there, people that are looking for more power and want to do cams. I don't think it makes a lot of sense for the average enthusiast, people like you and me, to pull the head off their low mileage daily driver and send it out with a bunch of money to be worked on. That's not the market I service in the Suzuki community.
So first I'll give you an analogy, so you can picture what exactly is going on, then an example of what typically happens when you increase flow through the cylinder head. People have a difficult time understanding the roll of turbo boost, but it's very simple.
Ever hold a water hose in your hand? What happens when you put your thumb over the outlet while the water is running? Maybe you've done this while washing your car. It's trying to maintain flow but it can't because your thumb is in the way, so what happens? It starts squirting wildly because the restriction is causing the flow to reduce and pressure to increase. One is a factor, or side effect of the other. As restriction increases, flow reduces as pressure increases. This is what's happening in your motor. The turbo is trying to push air through your motor but the the cylinder head, is creating a restriction, reducing flow, and as a side effect, increasing pressure. This is boost. So in this respect, boost is the negative side effect of airflow from the turbo and restriction in the cylinder head. Airflow is the ultimate goal, boost pressure is not. This is where people get stuck.
So about 15 years ago I was building and racing some factory turbo Suzuki cars. These were 993cc, three cylinder cars known in the U.S. as the Chevy Sprint turbo. The turbos are so small they fit in the palm of your hand. Versions of them were used on some motorcycles in the 80's. Everybody wanted to swap them out for a bigger turbo. They're way too small people would say. I thought they were perfect. Very little lag, and they could generate lot's of boost. We used to put bleeder valves on the wastegate actuator to reduce the pressure it saw and trick it into making more boost. Eventually I just disconnected the wastegate and it would generate about 25 psi under maximum load, and I could run a low 15 second quarter mile, 15.1 was my best. The cam was mild, 192 degrees duration at .050"/.332" lift. As you can imagine, there were no performance parts available, so I got a parts car, pulled the head and started development. I put together a few cam options, and since I was also driving this car on the street, put in a nice middle of the road performance cam of 226/.395". +34 degrees duration and .063" (that's a sixteenth of an inch) increase in lift. So what happened? I was now making power past 5000 RPM, to roughly 6500, though it would still pull hard to 7000, but the important thing was that with that little turbo running balls out, the max boost I could now make was 15 psi. I lost 10 psi of boost, the reason being that I reduced restriction in the cylinder head. So now with less restriction it was flowing much more air and with less boost (restriction = friction) less heat and much more power. The car was faster - by a lot, and much more fun to drive, especially since it now wanted to rev.
The end result, I knocked almost half a second off my time, was running a consistent 14.7 in the quarter, and set two land speed records in the standing mile on an otherwise stock motor. It transformed the car.
