ChrisJ
Been there, done that??![]()
Na,
But besides the fact there is close to zero airflow because of very little clearance around the fan, a typical refrigerator around that size is good for maybe 500-600btu/h.
Compare that to the smallest window A\C you can buy which is 5000 btu/h. That makes that fridge about 10 times too small not to mention the fact the fridge is venting the heat plus its energy consumption (100-200W) back into the room. The end result if anything, is a larger electric bill, spoiled food and a WARMER room.
Insanika I'm HIGHLY disappointed in you! Using an UNVENTED appliance to heat a space.
Just remember, a gas burner works just like a car engine. The less oxygen you feed it the more CO it produces and the gas burner will live much longer than you will on a lack of oxygen.:blankface:
