Dave@ddmworks
Supporting Vendor
Here is how we have installed them:
I had that same noise initially but my bracket was turned some. Now that it sits square I don't get it anymore.
Thanks for the input. Mine was on there pretty square. It was just too close. I could barely squeeze a strip of heavy paper in the gap. I had to rotate the bracket pretty far off to the side to get it to clear. It's only a temporary fix. I don't like how tight the MAF harness is. I may go back and redrill the mounting hole.
Edit: it looks like there are about 5-6 mm of clearance in Dave's pic. Mine was way closer.
Does the DDMWorks intake come with certification? CARB sticker?
Just realized that the hood prop rod hits the MAF connector on the DDM Intake. Anyone else notice this. I just bent the hood prop up a little around the connector. But the rod was pushing down against the MAF sensor with quite a bit of force. Also with the MAF connected on the front side of the intake pipe it really stretches the wiring to the MAF which concerns me a little. Is there any reason the MAF connector couldn't have been on the back side of the intake pipe? Just curious. I'm sure there is a good reason. The picture shows the rod after I bent it up to clear the sensor.
