Leaking antifreeze?
thatchickk
Many, many of us here have had problems with coolant loss/leaks/smells/etc... It happens. Far too often.
Water pumps are a good choice for a primary suspect. Check around the left side of the engine from top to bottom, perhaps you'll see a few stray drops. On mine, they accumulated on the engine cradle and splash shield, also coolant would also run down the oil pan. After replacing the water pump it has been fine so far, but I'm only 6k or so into the replacement so we'll see...
It should be covered under warranty.
thatchickk
xsonicLTZx
Natesriv
Lead Foot
Luv2xlr8
thatchickk
resolved?
So I took it to the dealer and they couldn't figure out where the leak is.. They put black light dye in the coolant and want me to come back Monday or Tuesday so they can shine a light under the hood and see where it's coming from.. Thankfully it's going to be covered under warranty no matter what it is!
did the dealer resolve your problem?
Luv2xlr8
heater blowing cool air at idle
i didn't notice antifreeze was leaking but was told to check fluid level for lack of heat/hot air at idle, it was low. turns out it was a leaky water pump which is a very common problem on sonics. hope this helps!!
moderator closed it out my thread before i could state what solution was
Swordsmith
242hp/252 ft-lbs BNR EFI
No members online now.
