jmwarren85
My windows don't stop when I put my finger in the way, it really hurt! Maybe its because I have a LS?
It only stops when you use the Auto up on the drivers window.
If you keep hold of the button, it will keep going regardless.
Just noticed today, it's raining. If your windshield wipers are on and you put your vehicle in reverse, the rear window wiper matches the speed of the windshield wiper even if it's not toggled on. Idk if this was mentioned or it's like a "duh" thing but I just noticed it
I'm glad I'm not the only one. I wasn't sure if it's supposed to come from the phone or the OnStar or what but I left it for a day and it still never updated.
Mine doesn't work either. I thought it was supposed to update the time when my phone is plugged into the USB port. Apparently Im wrong.
If anyone knows how to get this to work, let us know please.
Had my '13 in for its 3 month service today_ the auto-sync clock was one issue that I had asked them about. I've done research and found no solution so thought they might, but they had no clue either. They re going to call GM on Monday and let me know what they find. It's a small thing, really, but it should work. Could it be that GM's software Engineers simply overlooked a time-zone setting?
At any rate, if the dealer calls me, I'll be sure to come back and let everybody know what I learn.
Caveat: I did have to teach them how to do the MyLink upgrade so...![]()
Radio stations should be syncing their time by an atomic clock, just like computers are set up to do.
That doesn't sound like a great way to update the time. What if you listen to multiple stations on a regular basis, and they are all off of each other by a few minutes? You will never know what time it really is unless you turn it off like you said. Syncing to the cell phone would be better IMO. Most people use their cell phones for time these days.
... Nobody got my joke...
Sent from my Nexus 5 using Tapatalk
It's a bit of a non issue really. We've had to set our own clocks for years and this is just a feature of convenience.
If you really have problem with it, turn it off and set it yourself.
What did you plug into it, though? It says newer ipod/iphones are not compatible
BTW the rear deck fitting behind the seat totaly blew my mind!
Also does anyone know if there's a way to use Bluetooth as an audio source if you have the normal (not mylink) radio?
Has anyone used the AUX Video input on the MyLink yet? I saw the AUX option on the video display once when I was playing a video off of a flash drive and wondered where the input was.
Later I noticed the 4th pin on what I thought was just an audio input. Some early video cameras used a 4pin 3.5mm plug to connect the cameras to a TV via composite video, but the pinouts were not always the same. Not knowing the pinout I assumed that since it was designed to work with iPods that they may have implemented it in the same pinout as the early iPods.
I went online and found an iPod video out cable meant for for the early generations, before the 4th pin was repurposed as the microphone input. I attached it to a Raspberry Pi computer and I got video! In fact the MyLink automatically switched to the video input rather than the AUX audio you get when you plug a regular audio source into the plug.
This is the cable I bought if anybody else wants one. You could watch TV in your Sonic with a DTV decoder box!
Amazon.com : Macally Audio and Video Cable for iPod classic 4G, 5G, 5.5G (White) : MP3 Players & Accessories
