Ok I have both sides on now, and I'll tell you right now that you won't hear your rear speakers, maybe if you sit back there.
This might help , it's a rather large speaker with a smaller cone in the center
You have to remove the lower bpillar panel. It doesnt run into the door.
I got the LS model that didn't come with the rear speakers, so there is nothing back there, not even holes except one square hole.
You have to remove the front and back runner panels, then the bottom b panel pops off.
It pulls off.
Yes the rear speaker wires run from the radio to those plugs, but not into the door. You can tap in there and run into the door or whereever you like.
Thanks Sonic 007. So I can can snip the speaker wires off of that clip and tie the speaker wires onto them and run it to the deck? Thanks dude.
Yup. Will work fine.
