1-2 shift grinding status
Status
Not open for further replies.
klystron
Banned
Just to update everyone, the lawsuit has been ongoing for a couple of months now. I'll report results when it's over but I can't comment while it's ongoing.
Dustin
ChrisJ
Dustin
klystron
Banned
It shouldn't make an impact, but with the AC on the revs drop much faster and it doesn't grind. I demonstrated this to the dealer multiple times. I'm grasping at straws hoping it's something other than a design flaw in the trans as I don't want to go through the process of a lemon buy back.
I drove the car recently (first time since January) and had the AC on and it still grinds. Mine is actually getting much worse. It won't shift into second from third about 40% of the time. I have to put it in neutral and then put it into second. It grinds 1-2 and 2-3. It had a ~3 second grind into 2nd. Fully in gear but still grinding. Really weird. I shifted part throttle at about 2800-3000 rpm. In fact I had it grind on me about a dozen times while driving it for a week and never got on it at all.
I'm starting to think that the 3rd transmission that went in the car was not the charm and it's worse than it ever was. I've also still got the crooked hood from the dealer damaging it. If anyone gets a transmission replaced make sure you check how the hood closes. They use a brace to hold the engine up when they drop the k-member and trans and it dented up metal. I don't even know what damage is done to the front of the car having all that metal twisted and weakened. This whole car is a nightmare. The body shop bent some metal back into place and the hood looks sort of ok but it still isn't flush like it was. It's funny the dealer accused me of doing something and the body shop said it was caused by an engine support and wondered if any engine or transmission work had ever been done on the car. Ha.
It's starting to look like a legal resolution to this case is a year away.
ChrisJ
klystron
Banned
Fair enough, however I will point out it clearly did not fix the problem and they were probably thinking the clutch wasn't releasing fully.
Though, there are simple tests for that.
I still say you need a new dealer.
GM customer service sent me to two dealers. One refused to work on the car and the other sent me down this road.
klystron
Banned
Why did they refuse to work on the car?
I had the ultragauge plugged in so they brought out a printout about how they cause issues with on-star or whatever and said I voided my warranty. Refused to work on the car. In reality it's probably because as the service advisor said "didn't you tell him we don't have a transmission mechanic right now?"
Of course the warranty was not voided due to the gauge (as if) and the other dealer was very willing to work on the car. Unfortunately they not only failed to fix it but damaged the car. :(
Breezybro
$ub$onic
The Sticker Guy
mitdr774
also a dinner prick
ChrisJ
mitdr774
also a dinner prick
ChrisJ
ChrisJ
Status
