acamacho104
I am trifecta tuned, ecp enabled. I installed a cheapo godspeed catch can today and my ddm hard charge tube with synapse bov.
I followed the stuff I saw here for the catch can. Its intalled in the the pcv system. Used electrical tape to ensure it sealed up properly.
I installed the charge tube and ran the vacuum line from the bottom of the intake manifold to the synapse with a t to both holes like the instructions said. All I did was run a different piece of vacuum line from where it bypass mod line wasn I plugged the bpv solenoid when I did the bypass mod a couple months ago, so I didnt introduce new leaks there.
The block off plate went on fine and nice and tight.
I went out and hit okay boost in first gear(around 13-14 psi). It blew off fine, then I got no more bost than 1-2lbs. Restart the car and boost is back for one blow off, then nothing again. Can anyone help? Tried calling ddm but they are closed. The car is my daily so I need to figure itbout today.
