Ms.DannyStone
Still love it
PI0928: Bump, Surge or Vibration at Idle in Drive at a Stop - (Mar 8, 2013)
Subject: Bump, Surge or Vibration at Idle in Drive at a Stop
Models: 2013 Buick Encore
2012-2013 Chevrolet Cruze, Sonic
Equipped with 1.4L Engine (RPOs LUJ, LUV) and 6T40 Automatic Transmission (RPO MH8)
Vehicles Built Prior to January 1, 2013
Condition/ConcernSome customers may comment on a bump feeling, a surge or an engine vibration while stopped at idle with the transmission in Drive and their foot on the service brake.
Note: This condition is only when stopped at idle with the transmission in Drive and foot on the service brake.
Recommendation/InstructionsThis condition may be caused by the transmission Neutral Idle feature.
Important: The Neutral Idle feature will only function when transmission fluid temperature is 37°C (99°F) or greater. Verify that the transmission fluid temperature is 37°C (99°F) or greater before diagnosing this condition.
When the concern occurs, move the transmission shift lever to the manual position.
Moving the transmission shift lever to the manual shift position will prevent the Neutral Idle feature from functioning.
If the concern is eliminated by moving the transmission shift lever to the manual position, it is caused by the Neutral Idle feature and variation in the 1-2-3-4 clutch fiber plates. The 1-2-3-4 clutch fiber plates should be replaced with the part number listed below. This is a kit that contains two clutch fiber plates.
If the concern is not eliminated by moving the transmission shift lever to the manual position, it has a different cause and further diagnosis is required.
