I started digging through the diagrams on GMPD GMPartsDirect.com - Find a Item
Items 14-19 state cooling parts while 6-11 state there are oil systems parts. This would lead me to believe it is both water and oil cooled. However I can't find an oil return line so maybe that's what they mean by cooling pipe.
I generally run for 20 seconds or so to initially warm up, and then drive gently for a little while. The engine heats up much faster going 5 or 10 mph than it does sitting in my driveway.... but also running pure E85 it really has a stalling problem until the engine temp is over 60, so I have to rev it a bit, and it's actually easier to stroll then it is to sit in the driveway.
If I had one of those driveways that empty straight onto a 55mph highway, I'd sure as hell warm it up properly before moving, but I figure here in town I'm stuck going slow the first few minutes no matter what I might want to do.
I'm curious about this "run it a bit before turning it off" plan some of you are mentioning. Watching the engine temp gauge, it always climbs while sitting after running. Does it really make sense to raise the internal temps by deliberately doing this when you won't be running any fresh air past the radiator and intercooler?
Also my daughter's Altima has a fan that runs air across the coolant system for a few minutes after shutdown, might make sense to install something like that?
the main point to letting it "cool down" (i know that at a stop it warms up at idle) but this cool down is to get the hot oil and coolant out of the turbo so it doesn't cook any of the seals or have the already hot oil in the turbo cook more while it cools down after you shut off the motor. I'm not saying that you absolutely have to do this but it's good practice with any turbo that's why they make turbo timers.
Thats not why you idle down a turbo. Not because it is still spinning or to slow it down.
This was done ages ago (Google Turbo Timers) to prevent oil coking and extend turbocharger life.
As you all know turbos get hot, very hot. So they used to tell you to idle them down or use a turbo timer because when you stop the engine oil no longer flows obviously much drains back to the pan leaving the compressor and turbine housing way hot and oil coking can occur to the oil left in the turbocharger
By idling them down it will cool by running oil through the turbo and prevent coking of the oil left in the turbo at shutdown
Useless in modern Watercooled turbos
Hell the 35r variant in my EVO is DBB you can literally hear the turbo spin a good 10 min after shutting the engine off
Good to hear. I was hoping Opel wasn't shortsighted enough to repeat Saab's mistake. Oil-cooled turbochargers are for chinese ebay turbo kits.Gentlemen,
its water and oil cooled.
