California has some strict regulations for cats. My state of Washington copies California regulations and I am interested in upgrading too.
Here is a website with guidelines and rules/regulations on the installation of aftermarket cats under California rules
http://www.arb.ca.gov/msprog/aftermktcat/aftermktcat.htm
h) INSTALLATION REQUIREMENTS
(1) Installers of exempted new aftermarket catalytic converters shall adhere to the following requirements for proper installation. The manufacturer shall make these installation requirements available to installers of its products through its normal means for communicating with installers including, but not limited to, the VAC, the manufacturer’s website, requests via phone or email for technical help from installers, and other documentation distributed to installers. Installers may not install a new aftermarket catalytic converter in a vehicle unless all of the following conditions are met:
(A) The vehicle is specifically included in the vehicle application list for which the new aftermarket catalytic converter has been exempted;
(B) The vehicle is more than 7 years old or has more than 70,000 miles on its odometer;
(C) The vehicle is beyond the coverage of the OEM catalyst warranty period (which can vary from 7 years or 70,000 miles to as high as 15 years or 150,000 miles).2 Installers may reference the vehicle owner’s manual/warranty booklet or contact the vehicle manufacturer or its representative to verify the applicable OEM catalyst warranty;
(D) The vehicle has a legitimate need for replacement of the existing converter that has been established and documented by the installer on the repair invoice. If the OEM converter is present, the installer must make a determination that it is not functioning properly before acting to replace it;
(E) The exempted new aftermarket catalytic converter is installed in the same location as the OEM catalytic converter it is designed to replace. The front face of the installed catalytic converter shall be no more than three inches further upstream or downstream in the exhaust from where the front face of the OEM catalytic converter was located. The installation may not alter the location, position, or orientation of oxygen sensors upstream and downstream of the catalytic converter(s);
(F) The exempted new aftermarket catalytic converter is installed on a one-forone catalytic converter (not substrate) basis;
(G) The exempted new aftermarket catalytic converter is installed with all other required catalytic converters (no consolidation of catalytic converters, nor addition of extra catalytic converters is allowed); and
(H) A warranty card has been filled out by the installer, signed by the customer, attached to the repair invoice, and a copy returned to the manufacturer.
(2) Installers shall keep documentation regarding the installation of the new aftermarket catalytic converters including all of the above information. This documentation shall be made available to ARB or its representative as provided for in title 13, section 2222(b)(8). All such records shall be maintained for four years from the date of sale or installation of the catalytic converter
