My 2012 Cruze had the same PCV valve issue. If you car ran for a long period with the valve blocked the oil pan will leak. Look for oil spray around the oil filler cap. If you went long enough with blockage, the rings will be destroyed and will explain your oil loss. The oil will then clog and destroy your catalyst and possibly the exhaust side of the turbo. They will likely need to replace the rings, re-hone the cylinders and replace the first catalyst. I would recommend inspecting the turbo. I had an under boost issue that was hidden when the PCV issue occurred.
Seems to be somewhat common. The dealer that replaced mine when it cracked said that he's seen a few Sonics and a number of Cruzes with this issue.
+1. It looks like that initial problem may have caused all sorts of other problems and the dealer is having trouble figuring it all out. This is why you want your own scantool and why you want to figure out problems early. IIRC with my PCV and valve cover issue it was causing a vacuum leak and was throwing rich/lean codes. Also I wouldn't worry about the turbo so much, I think when mine finally lit up the light on the dash it went into limp-home mode or w/e and wouldn't build boost.
Oh and also they wouldn't check that because I asked them to. "Stupid car forums everyone thinks they know how to work on cars now!!!"
Scary. Back in the summer before the Sonic started regular production, Chevy engineers recommended using premium fuel in the turbocharged Cruze when summer temperatures got high. If the Cruze and the Sonic use the same turbocharged engine, then this statement would apply to the Sonic.
Hopefully the actual tech who does the work on your Sonic is better informed than his foreman, who of course was looking for a way to blame you. Sometimes I wish the government would throw out all franchise laws as they apply to vehicle retail sales and require manufacturers to be responsible. A warranty is fine but it does not protect a consumer from wilful ignorance or the appearance thereof as we sometimes see in the auto world.
Laborsmith
There are two different higher octane TSBs (one for the 1.8 and one for the 1.4t). The 1.4t deals with higher ambient temperatures and stalling. My Cruze 1.4t required 91 or it would stall at almost every stop in the summer. It appears that the tech is trying to place blame. Please talk to Pasty. She can help.
For reference, the 1.8 TSB deals with hard starts combined with LOUD engine noise during cold/high humidity mornings. TAC is currently working on a programming solution but has advised to only use high octane top tier fuel until a solution is found. I have been patiently waiting since October for a new ECM tune.
Just dropped the sonic at the new dealership. I'm curious about the fuel grade. The foreman told me I should only be running 87 in my turbo and that if I run higher grades I can see problems pop up. I was having issues with almost stalling and that's when I decided to change my fuel grade. So it almost sounds like he is trying to put blame on me. Anything I know about turbos is that a lower fuel grade can harm them. We will see what they say. The car runs like crap right now; my '89 VW Fox is quicker and healthier than my '13 sonic turbo. I shouldn't want to drive my 25 yo car over the new one because it runs better. Just sayin.
The owners manual even states use of 89 octane fuel as a minimum, 87 in emergencies and if 89 isn't available use the next highest fuel grade.
