Foxbox
I will see what photos I can find for you installed. It was on our test car for around 6 months, we only took it off since we started installing some other parts to test. The bottle and lines are actually still in the test car, just not hooked up to the install right now.
We ran a 35hp shot and also a 50hp shot on it, worked well with the controller that comes with the setup. The clutch can become an issue, but we actually ran the shot in the upper RPM range where the torque starts to fall off and not down low, which is probably why our stock clutch held it fine.
Hope that helps,
Dave
Appreciate the info very much.
I look forward to any photos you guys can share.
