Go big or go home!
BoostedSnail
iraqivet
Banned
i had to roll my fender cut the plastic inner fender and bend up the body weld like a 1/2 so i didnt cut my tire and i still rub
iraqivet
Banned
Iraqi whats a body weld? do u have a pic?
yes the body is pinch welded and it runs in the wheel well.
( and i thought you said you were low? because your not low if you dont know what that is because it ters up your tires )
this is one side after bending it up and spraying some paint on it
also this is what hapens to the tire
and just some other random damage from being low
and this is the trani snapped off the X tab and dragging it were the trani mount mounts
MPFab
Supporting Vendor
MPFab
Supporting Vendor
iraqivet
Banned
Here are some updated pics.
In order to keep from having to open the wheels up around the lugs, I opted to redrill to 103x5 and make some varience nuts to make up the difference. You can also see the hubcentric ring my machinist made for me as well.
Redrilled wheel
Closeup of redrilled wheels. You can see how much the tapered seat is shifted over
Bolted in place. Without really looking at this, most would not notice the lug nuts are off center in the wheel.
Damn I can't wait for the fronts to get back!
Frikin' MEATY!!
looks great.
MPFab
Supporting Vendor
iraqivet
Banned
Mounted a used 245/35/18 on one of the wheels today. Clears easily. 255/35/18 will be going on tomorrow. I'm starting to feel like 255/35/18 is gonna work at all four corners based on how well this 245 fit.
how close is it to the shock? on the inside
MPFab
Supporting Vendor
MPFab
Supporting Vendor
MPFab
Supporting Vendor
