Ok, this is the long awaited how-to for doing the pedal assembly.
I thought it would be easy but it's not. It took me 1 and a 1/2 days to do it and 2 people also a fully loaded DIY auto shop. Before I get into how to do it, let me explain how it's put together at the factory. When they have the dash outside of the car on the robotic arm, they put the pedal assembly on the back of the dash and hang it by two plastic hooks that are molded into the pedal assembly (which i'll illustrate in a picture) then they bolt in two bolts by those hooks to an arm on the back of the dash. Then there's an arm that comes down form the steering column that's mounted to the pedal assembly then with the pedal assembly attached to the dash, they insert the dash into the vehicle. then bolt all the pedal assembly bolts to the firewall. so as you can see, as i explain, you have to take your dash out.
1. Remove all plastic covers from dash and center console. (Also incl. radio, a/c controls, cubby holes, airbags, steering column, and glove box.) Remove the 2 bolts at the top of the pedal assembly that mount to the dash frame next to the hooks.
2. There should be 9-10 anchor bolts that bolt the steel frame of the dash to the vehicle. Also remove brake booster bolts and pedal assembly bolts, located under the hood on the firewall around the brake booster. There is also one bolt under the cowl/windshield wipers, on the firewall there next to the windshield wiper motor. disconnect clutch fluid lines from assembly.
3. At this point, your dash and pedal assembly. should be loose. You should be able to, with 2 people, one in each seat lift up and out on the frame of the dash. Only pull it an 1/2 inch to 1 inch out. Just enough to free the permanently mounted bolts in the pedal assembly from the firewall once the bolts are free from the firewall. Remove bolt behind pedal assembly that mounts to the lower steering column bracket. also disconnect any sensor wires to pedal assembly. Now the pedal assembly should be free and you can push up and towards the firewall on the pedal assembly to free the hooks off of the top of the bracket.
4. Remove old pedal assembly. Install new pedal assembly. Reverse Process.
Now I'm only informing you how I installed my new pedal assembly. If, for some reason, it doesn't work for you and your vehicle becomes damaged, I accept no liability. Follow these instructions at your own risk.
I do have more pic's of the job but not a lot i will upload soon
