tonycobretti
I think the engine bay in the Sonic is WAY too hot. Especially for an INGEN air intake. Rather than cutting open the hood for an air scoop, which would bring more dirt and bugs into the engine, do the following. First remove the thick weather strip from the top area of the engine bay. It is hooked in place, and can be carefully removed (and replaced for winter driving). When the hood is closed, this will create a 1" to 1 1/2" gap for excess heat to bleed out. Like a hood cowling.
Next thing to do is get a piece of thin stainless or aluminum plate (1/16" thick) 6" wide, and the length of the small opening at the bottom of the front area of the engine bay. Bend a 4" wide, 45 degree angle in the plate length and drill and mount it to the back area in bottom front of the engine. As you drive, the air flow under you vehicle will be scooped up and be directed into the engine block, cooling it, then up into the engine bay, and then out the top of the engine bay gap, where the weather strip was. The faster you drive the greater the cooling. An auxiliary oil cooler should also be added to cool down the engine. This will help the air-intake to draw in much cooler air and help prevent engine heat. Especially in the hotter months.
Remove the plate and replace the weather strip in winter conditions. It is very important to not over cool part of the engine or it could be damaged.
