rdss
Junior Member
So we can disable TPMS?
No, he's saying it needs to be added next or "Tested"....
Catless down pipe on the stock tune? Let me know how that runs if you can.
LOL.... This is only for the PCM/ ECM
Ah, that's right. Maybe one day someone will throw a short (or even a long tube) header and cat-less header to mid pipe.
Question. Here in NY, our emissions testing consists of plugging into the OBDII port and checking for codes. Would they be able to see that these sensors are disabled?
At least this is how it has worked on any other car I've done this to. Would like to hear feedback from BRN or Trifecta.
Bad Racing News?
LMAO
Correct. OBDII emission test structure and basic function is the same across all manufacturers (federal mandate). If you disable a monitor the test will show "not ready". Depending on the monitor the tech may try to set it by meeting a prescribed criteria on a short drive... only to be very confused when it doesn't set and will probably try to do diagnostic work on your car.They shouldn't see it. However it is likely that you will still not pass the plug in test. The ECU needs to pass all the readiness tests to pass the OBD plug in test. If one of the readiness codes are disabled then it will never get the positive readiness response for that particular test. When they plug in the car they will simply get a "OBD Not Ready" or something similar and send you on your way.
So make sure all your monitors are on and set before you go for an emissions test.
Is there any way to disable...say....the nanny traction control systems using this software? If so, would it still turn on when the button is pushed? I understand that you guys can't program this from a liability standpoint, but it would be interesting if users could easily do it for themselves.
nope. not happening.
Are you saying "not happening" as in it can't be done using this software, or "not happening" as in vendors won't give us any hints on how to do it ourselves? I'm already well aware that there will never be a tune released with this feature.
