Andrew, your car is becoming a photo whore! I like it!
Andrew, How close are your sawblades? I've got a guy up here in Dallas that has 4 9.5 inch sawblades for $100. Think it would be possible to fit these on here, how big of an adapter would I need if you have any idea.
I'm thinking a 32mm thick adapter will fit just right. That's what I advised a FB group member to buy for his 9.5"s. You'd need to stretch a 225/45 on them.
I came to 32mm because my 8.5"s were a couple mm off the struts and shocks at 20mm. .5" is 13mm so it should be a good fit with a little poke and stretch.
Tapatalking on my iPhone 6.
I appreciate the reply! You don't think 225/45 is too much stretch for 9.5 inches wide? I'd like as much rubber as I can without having to roll fenders or anything.
Nah, it's not a big stretch. The 225s will look good and give you the clearance you need.
Well I appreciate all your help sir. I'll give it a shot lol they're $100. I'm planning on stripping them then polishing them.
Quick question about adapters. I know where to buy them, so the adapter bolts up to OEM lugs, so do you use your OEM lugnuts to bolt it on, or do they send you some? Secondly, being that the Sawblades are 5x120 or something can't remember exactly. Would you need new lug nuts for the sawblades to go onto the adapter, or do they keep that the same as OEM sonic 12x1.5 (i think)?
