how did you remove the plastic foglight harness from the bumper?
Bought my kit from CED, it was perfect and complete. I was going to install myself but it would have cost an hour labor for the BCM flash anyways, so I checked to see what it would cost to see if my dealer would just do a complete install.... $115 later I'm happy. Well worth the money and for $310 total, not a bad deal![]()
Can you plz give me the link to were you ordered your foglight I want to order them for mine
This is the seller i bought the fogs.
100% safe.
GM 95950429 Fog Lamps Lights Clear Lens Gray Housing 24 Watt New Warranty | eBay
Regards
I installed after market kit myself. Never visited the dealer. Never removed the bumper. I did end up making my own mounts out of a alluminum flat bar that also works to dissipate the heat generated by the fog light assembly. I mounted my own switches inside and put a relay to cut off current when the high beams come on. I might post up a pic of the finished product after work. Again I never visited the dealer or took off the bumper saved me a lot of money but did take some time. Otherwise it takes away from the DIY if you take it to the dealer.
Sent from my SGH-M919 using Tapatalk
You used a non factory fog light switch that's why you didn't need to go to dealer. It needs to be flashed to the comp I guess.
Yeah absolutely thats why I chose this kit because I had no intention of paying the dealer to program something in plus I like the look of my after market switches
The Job you did look good, but as many over here i'd prefer OEM equipment.
Regards
Yeah I like oem equipment too but like to be a little different at times. The blue halo feature that oem doesnt have turns heads, thanks for the compliment. I understand that stock look a lot of us are fond of.
Where did you get that switch?
